Nello Posted February 20, 2015 Report Share Posted February 20, 2015 Chaps - Where the flippin' eck is the rear screen washer jet?............or am I going bonkers............. Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted February 20, 2015 Report Share Posted February 20, 2015 It's in the spoiler and squirts down... Mine stopped working and it ended up being the rubber hose coming apart in front of the battery. I had to re-attach it and use a cable tie to stop it coming apart again. Quote Link to comment Share on other sites More sharing options...
0 Nello Posted February 20, 2015 Author Report Share Posted February 20, 2015 Thanks Mike - will check as mine has as well...... Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted February 20, 2015 Report Share Posted February 20, 2015 One of the metal brackets hides it slightly... Your best bet is to squirt them with the bonnet open and look through the windscreen. My engine bay was saturated... Quote Link to comment Share on other sites More sharing options...
0 Nello Posted March 15, 2015 Author Report Share Posted March 15, 2015 Hmm mystery - Mike can you actually see the nozzle from within the spolier? I can see the 'hole' where its supposed to be in the centre of the 3rd brake 'strip.' Even with a torch I cannot see it. Wondering if its fallen inside the rear hatch somehow.......... Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted March 15, 2015 Report Share Posted March 15, 2015 No just been and checked and can only see a tiny hole in the spoiler. Are you sure you haven't got the same problem I had? Mine had the hose come apart where it was joined together just by the battery. Quote Link to comment Share on other sites More sharing options...
0 Nello Posted March 19, 2015 Author Report Share Posted March 19, 2015 (edited) You were bang on Mike - exactly the same - Hose 'joiner' had pulled itself apart right by the battery. Cable tied together now. One for the 'common Delta Issues'.................. Edited March 19, 2015 by Nello Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted March 19, 2015 Report Share Posted March 19, 2015 You were bang on Mike - exactly the same - Hose 'joiner' had pulled itself apart right by the battery. Cable tied together now. One for the 'common Delta Issues'.................. Glad to be of service Sir! Stick it in the knowledge bank for when I need some advice from your good self! Quote Link to comment Share on other sites More sharing options...
Nello
7 answers to this question
