timb02 Posted October 11, 2019 Report Share Posted October 11, 2019 The front bushes of the rear springs on my grand are perishing and I wondered if while I was doing these bushes should I do any others? your thoughts and opinions please folks!tim Quote Link to comment Share on other sites More sharing options...
0 Alex Posted October 18, 2019 Report Share Posted October 18, 2019 Hi. I recenlty did all bushes on rear springs. Mines Grand Voyager 2007 stow and go. Best to remove whole spring with shackles attached, easier to remove shackle bolts and cut big bush out. I changed all smaller rubber bushes on rear shackle as well,you have to reuse bolt sleeve if buy just bushe kit. One of mine wasn't great, fitted it. I'm still try to find a supplier for new sleeve. Also replaced roll bar bushes and links. Id also check shock absorber bushes, mine where still good. timb02 1 Quote Link to comment Share on other sites More sharing options...
0 timb02 Posted October 21, 2019 Author Report Share Posted October 21, 2019 thanks will buy a kit with all the bushes then. Probably best to do the lot Quote Link to comment Share on other sites More sharing options...
timb02
tim
