kapetanikolas Posted September 30, 2019 Report Share Posted September 30, 2019 Hello to all,I'm new here and glad I found this forum!I have a 2011 Delta 1.4 140HP stop-start in Oro version which has the simple radio-cd unit with blue and me.I have the possibility to acquire a used original navi unit for a good price to replace the radio.Before taking a decision on this, would anyone be able to advise me on the following: 1. Can the navi unit directly replace the simple radio/cd unit or would I need to modify connections, cables etc?2. Is it easy to get an activation code if the navi unit does not have one (still need to find this out from the seller)?3. What is the easiest way to get updated maps for this Marelli navi unit?thanks to allnico Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted October 11, 2019 Report Share Posted October 11, 2019 Hi Nico, and welcome to the club! The Navi unit will require the loom as the connections will be different. Unfortunately most used units don't come with any wiring, so you'll find it difficult to install. My advice would be to go for a good quality branded aftermarket unit instead as it will be much more straight forward to fit. Andrewgrale and Nello 2 Quote Link to comment Share on other sites More sharing options...
0 Andrewgrale Posted October 11, 2019 Report Share Posted October 11, 2019 Hi Nico, and welcome to the club! The Navi unit will require the loom as the connections will be different. Unfortunately most used units don't come with any wiring, so you'll find it difficult to install. My advice would be to go for a good quality branded aftermarket unit instead as it will be much more straight forward to fit.+1 Quote Link to comment Share on other sites More sharing options...
kapetanikolas
Hello to all,
thanks to all
nico
