Clutchnut Posted August 20, 2019 Report Share Posted August 20, 2019 Does anyone know of an available parts fiche. I've tried a search with no success. Quote Link to comment Share on other sites More sharing options...
0 Clutchnut Posted August 21, 2019 Author Report Share Posted August 21, 2019 I'm trying to identify the pt number for the unit that engages the lock in the rhs sliding door. Having to do it manually at the moment. But sometimes I forget to do it. And although the alarm will go off if someone opens it, I'd prefer to have it functioning correctly. Was quoted nearly £500 yesterday, but the guy was unsure if he was identifying the correct part. Quote Link to comment Share on other sites More sharing options...
0 bignev Posted August 21, 2019 Report Share Posted August 21, 2019 AHA now that I can help you with! Take a look on ebay for "Voyager lock actuator" and you will find plenty. Depends how quick you want it sorting but under £12 from China in 3 to 4 weeks or under £20 from the UK under a week. It isn't that bad a job, have a search on this forum and you will find it described by a few of us! To definitely confirm that's the culprit you can take the actuator motor from the other door and plug it on, they are the same unit with a different operating arm.Cheers, Nev Quote Link to comment Share on other sites More sharing options...
0 Clutchnut Posted August 22, 2019 Author Report Share Posted August 22, 2019 Thank you. I've already had it off to diagnose. I'll have a look tonight when I get home. Quote Link to comment Share on other sites More sharing options...
0 Clutchnut Posted August 28, 2019 Author Report Share Posted August 28, 2019 Job done. Ordered actuator on Friday, arrived this morning. 20 minutes to fit. The only thing I had to do to get the old one off when I originally diagnosed the problem. Was to drill an access hole to get at the top T15 torx mounting screw, as the factory access hole is about 4cm too low and about 1.5cm to the left. Quote Link to comment Share on other sites More sharing options...
0 bignev Posted August 28, 2019 Report Share Posted August 28, 2019 Marvellous, I must have blanked that part from my mind as I don't recall having to make any more access, do remember dropping a screw inside the door though ? and forgetting to put the polystyrene block back in before I put the door card on..... I left it out for a couple of years till the actuator went noisy and I changed it again. Skydiver 1 Quote Link to comment Share on other sites More sharing options...
Clutchnut
