The Automatic Transmission Does Not Go In Sequential ... Only Automatic Drive!
Tommy72
... the automatic transmission does not go in sequential ... only automatic ... moving the lever to the right and left nothing happens ... the change works very well already done maintenance ... I assume problem of selector ... already purchased used piece ... can 'be another before it does dismantle the whole plank for replacement? thank you! :o
... no anomaly diagnosis ... in drive mode it works perfectly ... no lock in 3 or reverse ... moving the selector just does not even activate the display indicating the gears ... I think it is really a problem of sheared wires internal selector as from the research I found ... the selector is also a bit shaky in sequential! thanks :)
