neilw Posted August 5, 2019 Report Share Posted August 5, 2019 I had a diagnostic fault on my 2007 300c which came up as low voltage on all 6 injectors and car would stop.After further investigation I found the wiring loom that feeds the injectors had rubbed through two cables and shorting out on the AC pipe adjacent to the loom.A bit of insulation tape and moving the loom slightly so it was not rubbing on the steel pipe and all seems okHope this helps someone else as it was like looking for a needle in a haystack.RgdsNeil Quote Link to comment Share on other sites More sharing options...
