I am having issues with the air con on my 2.8crd. When I bought it the guy said the air con just needed a re-gas and I foolishly thought that would be it, however I am beginning to think that this may not be the case. A little investigating and the 40a fuse for the rad fans was missing(?) so replaced with no ill effect. I cannot hear the a/c pump cutting in when the a/c is switched on and the fans do not cut in. The unit in the car also does not go into automatic mode i.e. the air direction and fan speed indicators stay on. anything anyone can suggest to look at please? Would low gas pressure cause the unit to shut down or is it not that sophisticated. thanks in advance for your thoughts.
timb02
Tim
