This was a problem I solved by myself and going to share with you guys, when you pull the lever to unlock the back structure there's a cable that connect's to the other side, it gets loose and don't aloud to unlock both sides, only the lever side unlocks.. there's a plastic point on one side that can be re-set to stretch the cable but if that's not enough use a cable locker as a spacer.
PauloOliveira
