Thought I would start with some basics, so thought I may clean out the EGR valve, the removal process was explained so easily in the manual, .................
Whipped of the wipers, wiper panel and wiper motor assembly etc not a problem.
Then I got to the EGR unit itself.......!!!!!!!!!!
Has anyone, successfully changed or even removed the EGR valve with the engine in place????????
I can remove the two bolts holding the hose / pipe but I can only see one nut down to turbo, the other is covered by the exhaust heatshield, I'm not sure I can even touch it, let alone get a socket/spanner/hammer to it!!!!
The hoses along the back have the most awkwardly placed clips (with the sharp side out) and everything is tucked up behind far too much pipework.
VoyagerPig69
Hi again all,
