On hills the car heats up excessively nearing the red line - returning to normal once things level out.
When i'm on the flat, small hills, driving steady, motorway driving or sat in traffic the car is fine and the temperature sits around halfway.
I've check the fans after driving up a hill and when the temperature is nearing the red and they are both running really fast. The car has not actually ever gone into the red... but then again ive not been up a long 5 mins+ hill to test it.
The radiator water is clean, and radiator flushed through without blockage and has new coolant.
I've started to suspect the fans should kick in sooner that they do? Is there a low level fan that should come on?
ie i think the fans dont kick in until it gets really warm.... whereas i would expect them to kick in when the temperature starts to rise a little way above middle to regulate it.
Its hard to test this but when ive seen the temperature just going over middle of the gauge (if ive been able to stop and check) ive noticed no fans running.
Any suggestions from anyone would be greatly appreciated.
chrisdavisberry
I have a 2006 2.8 CRD Grand Voyager
I have one issue with it I cant resolve.
Chris
9 answers to this question
