Recalls do not apply to all countries, model variants and often only involve a very small production run. If you are unsure if any of these recalls are applicable to your vehicle or you require more information then please ask at your nearest dealership or VOSA.
T14086
5306 - Sunroof glass - Possible leak at sunroof
5324 - Turbo - Possible oil leak at turbo pipe
5316 - Sat Nav - Software update
5317 - Lambda sensor - Check lambda sensor wiring
5334 - Sunroof - Possible water leak at sunroof
5340 - Servicing - Instrument cluster software update
5362 - ECU software - Software update for Engine ECU
5382 - ECU - Software update for Engine ECU
5490 - Blue and me - Software update
5619 - Engine mark - Incorrect engine markings
5650 - Steering column - Steering shaft replacement
5702 - Mirrors - Possible deterioration of door mirror cover paint
5724 - Cylinder head screws - Tightening of screws
5733 - Data plate - New vehicle data plate
5807 - Gearbox - Possible oil leak from Gasket
5810 - Owner manual - Supplement update
