Air Con Compressor.
Eyore28
Hi guys and gals, I am after some advice.
Should I attempt an air con compressor replacement? I am reasonably handy with the spanners having spent 12 years in the REME although not as a mechanic. Are there any special tools required?
The reason for needing to do this is the compressor clutch sheared off a couple months back so the pulley is only acting as an idler now.
2.8 i presume? Resonably easy, but you obviously need to recover the gas 1st. Illegal to vent to atmosphere! 13mm sockets, extentions etc.
Wind the pas drive belt on/off, no tensioner.
Forgot to mention to make sure the new compressor has oil in it. Turn upsidedown and drain into a container the old pump, do the same with the new and compare the amount of oil, then refill.
Edited by moggies
