Radio Code
jakedamuss
Hi When I had my battery out and put a new one in the code for radio was saved by the ecu and came back on again put if you want a code number for it you have to take the radio out on the it is the serial number go on Ebay a seller will give you the code number when you give them the serial number. Jeff
