I have a 2006 model (Registered Dec 2005) Chrysler Grand Voyager 3.3L V6. I have brought some new Autolite AP5426 spark plus. I have removed NGK Iridium plugs.
As you can see from the listing from eBay below, the Autolite ones appear to be correct but......... when I checked them before I bolted the heads back on, they appear to be longer than the Iridium ones to the point where one protrudes, fractionally, below the the head/into the bore. I've replace the head gasket and had the Heads skimmed.
"6 x SPARK PLUG PLATINUM AUTOLITE AP5426 - CHRYSLER VOYAGER 3.3L 3.8L 01-07"
Anyone else had this issue? Are the Autolite ones good to use? Should I be sticking with the Iridium plugs?
AustinM64
Hi There,
Cheers
Austin
