Engine Cutting Out Again
legonsuk
Has anyone had a crankshaft sensor go on there Grand voyager 2.5 or 2.8 crd if so what was there symptoms and did you get the engine management light come on or a code on the key dance as i have got the dreaded engine cut out problem again witch i fort i had sorted the problem out car starts fine all the time driving a long accelerate hard and it cuts out no lights come up on dash to say its cut out like battery light  abs airbag or fuel lights pull over turn the ignition off and on again give it a second then starts first time and away you go any info or help will be great as i have a very big club hammer dying to meet my voyager lol .
Cutting out on booting it nothing to do with Crank Sensor. Crank sensor often doesn't leave a code when it goes as it just goes. Try the MAP which logs the boost pressure, you might just get away with cleaning it as its normally covered with carbon crud. If it doesn't cut out engine and just go into temp cut power mode, its the Turbo actuation side like operation of the gate actuator. Look for P0235 here.
Bad Crank sensor or ring  should activate EML - well it did on mine 2008 MK5 not 100% sure on MK4.
Usually it is the valve at the end of the fuel rail that leaks under gigh pressure and replacing him usually helps for 2-3 years.
+ clean or replace MAP sensor.
+ clean EGR if you can (or block it) it will help.
There was a very good video on YouTube while ago done by @@Andy from here targeting all areas of cut off problems.
