Strange Headlight Fault
imac2626
Hi everyone, I've got a 58 registered grand voyager. When I remote unlock my car both headlights come on, yet, when I start the car and turn the headlights on only the offside headlight works ? it can't be a fault bulb as they both work on remote unlock. I can't work it out nor understand it, any help please?
Had the exact same issue in my 2009 GV. Turned out that there is an additional small fusebox housing 4-5 "regular sized" fuses right next no the main fuse box under the hood. One of those fuses had gone.. Replacing it fixed the issue. (Which made me extremely happy, as I'd already heard that similar symptoms are often caused by a failing head light relay - and I much prefer changing just a fuse..  ;)  )
