Gearbox Slipping When Warm.
harris266
ll
I have a 2004 voyager 2.8crd.  gearbox has started playing up but only seems to happen when warm. From cold changes nice and smooth but as soon as warms up it seems like the box is slipping.  (similar to a manual clutch slip)  If you rev the engine it will engage again but soon after starts to slip. Have changed the oil last week. That made it a lot better but there is still signs of slipping. When engine is cold it changes through all gears lovely and pulls like a train. No unusual noises either. Anyone any ideas please.
Mark
im no profesional nor a mechanic
years ago i had similar problem with a vauxhall carlton
i had the gearbox oil changed with new filter that seemed to work if i remember right
but from memory there was something later wrong with the torque converter
thing with auto gearboxes is no one wants to touch them that ive found
1 reason i was given was they are built by magicians and worked by witchcraft !!lol
i wish you luck hopefully someone else will have a better explanation and can help you better
