flinx49 Posted December 13, 2018 Report Share Posted December 13, 2018 I own a 2004 grand voyager crd limited,2.5 diesel engine.During the winter in Bulgaria and the temperature drops to -5c and below the engine will start and run for maybe 2 minutes when under load or ticking over,and then cuts out 1 minute later the engine will start again run for a short period and then cut out again . At the moment it is +8c outside and the engine is ticking over no problem . When running in cold weather the engine running temperature is very low . any help from the forum would be appreciated . Quote Link to comment Share on other sites More sharing options...
