I have just replaced the clutch and rear crankshaft seal on my 2003 GV have got the car completely built back up and the engine has seized solid it won’t even turn with a bar on the crack pully..... I fear I may have done up the flywheel bolts to tight I done them to 100nm
Can anyone confirm if this is far to tight and have the correct torque spec for it, or simply any other suggestions of things to try before I take the box back off.
Stringer87
Hi all,
Many thanks in advance
9 answers to this question
