Josboogz Posted November 3, 2018 Report Share Posted November 3, 2018 hi All, Does anyone know the sump plug and or washer part number for the 1.4 M air (140) please. A link of where to buy from would be greatly appreciated. Thanks, Quote Link to comment Share on other sites More sharing options...
0 Cassino Posted November 4, 2018 Report Share Posted November 4, 2018 The best way is to check it out at a Fiat,Alfa ,or Jeep franchise....as the multi-air engine is used across the FCA range.....does not have to be a Chrysler part.Ian Quote Link to comment Share on other sites More sharing options...
0 Nello Posted November 5, 2018 Report Share Posted November 5, 2018 My online eper access is slow at the moment - better during the evening when its quiet so will check later - As Cassino says though it will be common across all FCA vehicles that use the MA engine - pretty sure it'll be the same as the one for the MiTo - https://www.shop4parts.co.uk/?name=store&op=Results&category=14&secondary=35&opts=3753&term=Alfa_Romeo_Mito_1.4_TB_MultiAir_(135/170_Bhp)_Sumps Cassino 1 Quote Link to comment Share on other sites More sharing options...
0 Josboogz Posted November 5, 2018 Author Report Share Posted November 5, 2018 Thanks for the help guys much appreciated . When I get my Delta serviced will confirm back on the thread Anyone changed the spark plugs yet? Reluctant to do mine as car still feels ok at 50k. Cassino 1 Quote Link to comment Share on other sites More sharing options...
0 Cassino Posted November 5, 2018 Report Share Posted November 5, 2018 (edited) I have just ordered a set of plugs,not cheap,but they are iridium tipped, and should do some serious mileage.....My odo reads about 51k, not sure if the plugs fitted are original, but it had a service at the 34k point, and were they changed?....not sure,? Has anyone had their head filter changed???.....it's a gauze filter that is replaced complete, but there is no mention of it in the handbook.....and not cheap..Ian Edited November 5, 2018 by Cassino Quote Link to comment Share on other sites More sharing options...
0 Cassino Posted November 5, 2018 Report Share Posted November 5, 2018 Josboogz.....make sure the correct oil is used in your service..... it's gotta be C3 !!!!!I use Castrol Edge.......that old multiair relies on the correct oil...Ian Quote Link to comment Share on other sites More sharing options...
0 Nello Posted November 6, 2018 Report Share Posted November 6, 2018 if you do not know when the plugs were last changed I would do them now. Just make sure you have a long plug socket as they are buried deep down within the head. Quote Link to comment Share on other sites More sharing options...
0 Josboogz Posted November 17, 2018 Author Report Share Posted November 17, 2018 Cheers Cassini, had the delta for 3 years always use Selinia pure k energy as per the manual, never given me any trouble Car is going in a week on Monday so let you know on the sump plug. Got mine from Jamie Porter - Alfa specialist Cheers Nello, Dont think the plugs have ever been done. Might see if I can get a set before then goes in. Cassino 1 Quote Link to comment Share on other sites More sharing options...
0 Josboogz Posted November 19, 2018 Author Report Share Posted November 19, 2018 Bought these... https://www.alfaworkshop.co.uk/parts/Giulietta_Spark_Glow_Plug.shtml Same part number referenced in Eper. Looks like the original spark plus are ngks Will report back post service Quote Link to comment Share on other sites More sharing options...
0 Cassino Posted November 19, 2018 Report Share Posted November 19, 2018 Yes plugs should be NGK IKR9F8.......... Quote Link to comment Share on other sites More sharing options...
0 Josboogz Posted December 2, 2018 Author Report Share Posted December 2, 2018 Just to confirm got my Delta services and MOT by my local indie. Sailed through MOT:) Sump plug and washer from mito from Alfa workshop was fine. Spark plugs were also right, car feels a lot better a lower revs. Glad I got it done, thanks for the advice chaps Cassino, Nello and MikeyRules 3 Quote Link to comment Share on other sites More sharing options...
Josboogz
hi All,
Thanks,
10 answers to this question
