Perform Service Indicator
Victorthevoyager
10 answers to this question
Out of the 30 views no-one knows? Surely someone has a clue. Is there a sensor for when the oil filter is past it’s best or the viscosity of the oil has degenerated? What is the normal interval between services? I had the oil and filter changed today just to be safe as I have a 800 mile round trip this weekend. Come to think of it, the last time the perform service indicator came on was just before another long journey. Maybe the car is psychic!
Whilst resetting the perform service indicator you may not have notice you can reset the distance to the next service. It starts at 3200km and goes up to about 14000km
Hi Semmysonic, Thanks for your reply. I didn’t know that you can set the distance to the next service, I’ll have a look at that later today.
Cheers, Paul
Found it on the Internet. Follow steps:
1. Ignition on
2. Press the reset menu button until the service interval is displayed
3. Repeatedly press the step button until the desired service interval is displayed
4.Press the C/T button until the display changes
5. Press the step button until YES appears ( I didn’t get this )
6. Press the C/T button then switch the ignition off.
The service interval should now be set to whatever you selected, I chose 10000 Kilometres which is roughly 6000 Miles but there were quite a few to choose from.
Hope this helps someone else with the same problem as I had, and thanks once again to Semmysonic.
Cheers, Paul
