Hi. i have a grand voyager 2005 3.3 v6 petrol automatic. when i select drive and try to accelerate there is a serious lack of power. the engine idles perfectly, but takes forever to pick up any pace, and when i get above 40 (eventually) there is no gumption to want to go much faster. it takes an eternity to get up to 60.
the gears don't change as they should. the revs get to 3 and a half thousand, and the rev counter begins to bounce and will not change up gear until you let the throttle off it drops to around 2 thousand, will change up, but if i press too hard on the throttle it will down shift shoot up to the 3 thousand mark and the rev counter bobs.
Now i have changed spark plugs, cam sensor and crank sensor as per diagnostics, to no end. I've had it checked with the star scan tool and found the timing was out, therefor i had the timing done also. whilst it was in getting the timing done the mechanic noticed that the manifold was a cherry red color and suggested that the engine wasn't breathing properly. once the timing was done i removed the exhaust system to check the cat and other pipes for any obstructions or blockage. Again i hit a wall and found hee haw.
i am at a complete loss as to where to go next, because regardless of any parts being serviced the car still will not accelerate as it should.
Can anyone help?? Has anyone had this problem?? Is there something i'm over looking far simpler?
I may well be looking too deep. Any help or advice would be greatly appreciated.
SandSAutocare
Thanks in advance.
12 answers to this question
