Diesel Cabin Heat Assist
BumBle02
I'm assuming you have a Webasto thermotop, NOT a cabin heater. Left to its own devices it will just work if (1) its cold enough and (2) if you are at least 1/4 full of fuel, it warms the big cold lump of an engine, turn it off and engine efficiency goes down and fuel economy also goes down. If you really want it switched off get underneath the car and unplug the electrical connector near the unit, denied a power supply voltage it will go dead along with its brain. ((Its possible someone fitted an ex Erberspatcher airtop in the cabin - this does indeed blow warm air)) We all have to learn including me, all questions and answers are knowledge and that's why we use forums. Take care !
