How to disconnect the valve for no cost and it works disconnect the vacuum pipe that is fitted to the side of the valve on mine the pipe goes to the top of the engine block connector disconnect it there and cap it so no vac lost the little bit of exhaust will fool the sensors. No engine light will come on it runs a lot better and oil stays cleaner and will pass a mot and good if your valve goes faulty on a CGY 2007 2.8 Cdr the one on front of Engine going to try a power box and KN filter to see if they work will let you know if they work.
BumBle02
Edited by BumBle02Link to comment
