Ypsilon Lights
blackandred
Hi all just joined forum posted hello in newbie section.
She got the car last easter after having a mini one with problem after problem. However just got a problem with the lights on Ypsilon, been away for a couple of weeks and when I started car the dipped lights were on even though the light switch stork was to off. They are now on all the time unless ignition is off, does anyone know if it would fail mot like this. I have had a quick look and part number on the column switch is 07356221850 does anybody if any other parts are interchangeable from other fiat's, panda's 500 etc. The Ypsilon is a 62 plate 1.2 black and red, also would anyone have any info on removing the airbag so I can get steering wheel off.
Thanks Kirk.
