Hi all, it’s been a long time since been on here, which as our Grand Voyager has been behaving himself for the last few years I’m guessing is a good thing !!!
Few weeks ago front end making some strange sounds and drivers side shock had punched through the turret.
New shocks (after market not orginals) fitted both sides and all good..... OTHER than steering now pulling massively to the left and steering wheel massively out of centre.
Popped down the tyre place and they adjusted it all up and now whilst not quite perfect, it’s acceptable for now....
HOWEVER.... today I noticed that passengers side wheel arch is sitting nearly 30mm higher than drivers side ????
Everything else seems ok (other than seem to introduced a slight squeak/creak on steering but have seen some grease nipples so am assuming this this do-able...
Sooooooo..... any suggestions as to what may have caused steering to be so massively out on what I assumed was a straight swap out.... and any thoughts on what may be causing such a noticeable ride height difference.
New shocks and coils all looks good out the packet and weren’t from eBay....
markyb7
Thanks guys !
