Hello, I have a 2006 Chrysler GV 3.3 petrol that has just had the flexplate replaced. I also replaced the cam and crank sensors and in attempting to start after the repair I found I had low fuel pressure so I replaced the fuel pump as well. . First start after the repair the car started perfectly and ran great. However as soon as the car warmed up I had the engine light come on with the error code P0016 again. Next the airbag light came on and so I checked all the yellow connectors I could find under the seats & below the ashtray/centre console. Cleaned all the ABS ring gear and sensors but still no joy. Can anyone tell me if there is any correlation between the airbag light and P0016?
lessuth
Cheers
