Gutless Voyager Se
peedoff
Hi there, could possibly be the coil, I've had a couple die on me.
There is a thread on here probably earlier this year, but are you able to test stuff? You will need a spare spark plug, pull one HT lead off at a time and push in the spare plug, rest it on the metal cross member, start the engine, and see how the spark looks.
Work your way through all  the plugs, if one is particularly less bright than the others it's probably the coil, but try swapping the leads over on a couple of connections on the coil to check it's not them.
The coil can be had off ebay, or rockauto.com in the USA, I actually (as daft as it sounds) bought 2 from them for the price of 1 in the UK, shipped over in 5 days.
Or it could be a HT lead, but from what you describe it is just like mine when it chucked its hand in.
Oh I should have started with the "key dance" suggestion - key in, at "off" position, and in fairly quick order, go to ignition on (but NOT cranking position) then back to "off" then igntion - the third time you get to the ignition position stop, and the trip meter should show us some info, P codes, if you get P0301 to P0306 then that's a misfire detected. P0300 is multiple misfires, the second time the coil went on mine it had killed 2 circuits.
