Italianstallionxx Posted July 9, 2018 Report Share Posted July 9, 2018 HelloJust wanted to know how you test an electric feed on 2007 Grand Voyager Exec X'S. My sliding door actuator had given up. I put a test light on it and nothing lights upI put a multi metre on it and no feeds when I use the fobs. But I know there is a feed there as the actuator twitches a bit,nit enough to lock the doors. So.........how do I test for feeds apart from buying new actuator and fit it......an expensive path if it's not that Help much appreciated Quote Link to comment Share on other sites More sharing options...
0 bignev Posted July 9, 2018 Report Share Posted July 9, 2018 If you are talking about the locking actuator, the simplest thing to do is get the one off the other door and try it, they are the same with the arm being handed, but if it twitches and is unable to pull the latch up or down it's pretty much certainly dead. They can usually be had new off ebay for sensible money. Quote Link to comment Share on other sites More sharing options...
0 Italianstallionxx Posted July 10, 2018 Author Report Share Posted July 10, 2018 Ok So as for the voltage readings,why could I not get a reading ? Quote Link to comment Share on other sites More sharing options...
0 bignev Posted July 10, 2018 Report Share Posted July 10, 2018 Don't know on that one, unless it's so brief it didn't register on the meter. Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted July 10, 2018 Report Share Posted July 10, 2018 Suspect that you might be testing the CANBUS network feed which probably carries the trigger signal for the door actuators rather than a "classic" voltage high to run the motor.I'm just guessing here though, would need to dig out the wiring diagrams, but based on other things on these I'd expect there to be constant 12v feed, then a signal/CANBUS wire that signals to the electrics in the door/actuator to operate. Agree with bignev though, if it twitches, then it's getting the signal to operate just motor has gone weak or the internal plastic wheel has chewed up. Quote Link to comment Share on other sites More sharing options...
Italianstallionxx
Hello
