Ok so it did it again for the third time. I went for a good run stopped get some BBQ supplies ? then when I to start -Zilch !! only the lights on the cluster.
The suns blasting down my supplies are going to perish.
Eventually after much panic and twiddling with the ground wire/plug on the starter I got her running again.
I'm awaiting the delivery of my new fuel filter housing so i'm gonna take the starter off at the same time. Maybe i should order new brushes ??
Each time it's done this fiddling with that ground wire has got her starting again.
frogland
