scrufgp Posted June 30, 2018 Report Share Posted June 30, 2018 hey peeps just wondered if anyone has encounteered problems with the leak off pipes these are the small (about 4")bits of braided hose between the injectors on top of the engine between the injectors seems to be 5mm pipe with 5mm plastic conectors ??but the last 1 that then drops away to the left hand side off the block is 3mm ?? is this a specialist bit of hose ?as i cant find 1 if it is nor can i find a reducer of 5mm-3mm or has my car be tampered with ??the bit of pipe that ive removed was 3mm stretched to fit over the 5mm and atm replaced with 3mm !!! Quote Link to comment Share on other sites More sharing options...
0 legonsuk Posted June 30, 2018 Report Share Posted June 30, 2018 Done them about 2 weeks ago ebay 202129580000 i got the 3.5 mm x 7.5 mm 500mm hope this helps m8 . Quote Link to comment Share on other sites More sharing options...
0 scrufgp Posted June 30, 2018 Author Report Share Posted June 30, 2018 Done them about 2 weeks ago ebay 202129580000 i got the 3.5 mm x 7.5 mm 500mm hope this helps m8 .thnx for the reply just looked at that listing !!did the pipe fit over the 5mm connectors on the top of the injectors ok ?i know the pipe has a little bit of stretch in it but my personal thinkings 3.5mm pipe to 5mm connectors are a bit too tight due to location of the pipe with the heat from the engine and the fact that they are wrapped up in the sound proofing blanket i worried being so tight will just cause them to split again!! Quote Link to comment Share on other sites More sharing options...
0 legonsuk Posted June 30, 2018 Report Share Posted June 30, 2018 The pipe i got was ok just used a bit of spit lol to lube up the pipe so it went on a bit more easier . Quote Link to comment Share on other sites More sharing options...
0 scrufgp Posted June 30, 2018 Author Report Share Posted June 30, 2018 cool ill give it a try see how it goes thnx for your advice legonsuk 1 Quote Link to comment Share on other sites More sharing options...
scrufgp
hey peeps
