blackvelvet Posted June 18, 2018 Report Share Posted June 18, 2018 Just had the Grand Voyager in for a transmission filter and fluid change.I have now noticed a vibration from the front end of the car, coming up through the steering column.It happens quite often on a journey, almost like there is a bad road surface.I don't know what the problem is, but it has only started since the fluid change.Any ideas? Grandadssupervan 1 Quote Link to comment Share on other sites More sharing options...
0 Grandadssupervan Posted June 26, 2018 Report Share Posted June 26, 2018 Hello mate..I’m fairly new here too...does yours do it when pulling away from a standstill and does it also do it while sitting still in drive at traffic lights for instance? Quote Link to comment Share on other sites More sharing options...
0 blackvelvet Posted June 28, 2018 Author Report Share Posted June 28, 2018 No my car did it only while moving.My mistake was associating the whole deal with the fluid change.I spent all day on the car myself., it was a number of problems that occured all at the same time.Transmission was a litre short, garage's fault, but mine also for not checking the work they did.The left hand tyre was unbalanced.Getting these things fixed cured most of the vibration.The noise over bumps appears to be the top of the strur.Check your trans fluid, if it's not right it can cause vibration, even stationary if you keep it in drive. Grandadssupervan 1 Quote Link to comment Share on other sites More sharing options...
0 Grandadssupervan Posted June 28, 2018 Report Share Posted June 28, 2018 Hopefully I’ll get time to change my oil & filter this weekend Quote Link to comment Share on other sites More sharing options...
0 blackvelvet Posted June 28, 2018 Author Report Share Posted June 28, 2018 A change of fluid cured the noisy reverse gear and slight vibration through the column on my car.It's an easy job. Just get the car high enough, safely, and have a good size bowl ready. A washing up bowl from Wilco will do, and use ATF +4..... not cheap but worth it.I also noticed in the Chilton manual, they recommend silicone sealer for the sump gasket. Quote Link to comment Share on other sites More sharing options...
0 bignev Posted June 28, 2018 Report Share Posted June 28, 2018 Yes and leave all corner bolts in the sump till you break the seal or it will piss all over when it gushes out suddenly!! Well mine did!!!!! Yep I agree, the twice I've done it (no surprise oiling the 2nd time though) I used normal automotive RTV silicone. Grandadssupervan 1 Quote Link to comment Share on other sites More sharing options...
0 Grandadssupervan Posted June 28, 2018 Report Share Posted June 28, 2018 I’ve got a pump so will pump most out through dip stick hole Quote Link to comment Share on other sites More sharing options...
0 bignev Posted June 28, 2018 Report Share Posted June 28, 2018 Aha!! Smarty! Grandadssupervan 1 Quote Link to comment Share on other sites More sharing options...
0 BumBle02 Posted June 28, 2018 Report Share Posted June 28, 2018 Yes I just got one from eBay works a dream doing mine tomorrow will get oil over me if there is oil it loves me . Grandadssupervan and bignev 2 Quote Link to comment Share on other sites More sharing options...
blackvelvet
Any ideas?
8 answers to this question
