OMGoodness, what a right mare we have had with this.
We began Saturday late afternoon for about 3 hours and then from Sunday 10ish right through to 8.30pm and still not complete. Luckily still have our old Astra to run kids around.
First observation, the pan was already having a slight leakage at one side, so this job needed to happen.
So my husband unbolted and carefully using the spatula (wallpaper scraper), slowly tried to release the pan - the oil actually burst out of the sides of the pan and then the pan landed in the oil pan catcher with my husband hands holding it to stop it from getting damaged, was covered, literally an oil bath.
Cleaned up, removed old silicone etc, degreased with the brake cleaner away from the car naturally.
We took our time and did not rush so was super careful with every process.
First attempt: We used that Grenville Gasket sealer and followed technique for putting pan back. Didn't look like any leaks initially, but when we topped up with the new oil and then worked the gears - following the instruction which came with the dipstick - it started to leak in the same place where we noticed before starting this job.
Obviously couldn't carry on, at this point already put in about 3.5l of oil.
Removed pan carefully, he left two bolts loose this time so it didn't come away sharply like first removal.
We caught all the oil in a clean pan as no room for error only bought in what you linked.
Second attempt:
Cleaned up as before, degreased and dry surfaces to work with.
This time we only used the rubber gasket which came with the filter kit.
We put the caught oil back in through a cloth muslin strainer to catch all the bits which were airbourne landing in the pan - this worked well and we saw this technique on youtube when someone had a similar problem.
Again waited, followed instruction for dipstick and within minutes the oil was weeping through a different side of the pan
Third attempt.
Removed, cleaned and used the silicone and gently placed the rubber gasket over and then fitted pan - so far so good doesn't seem to be leaking, will need to check again tonight though to be sure.
So the amount of oil to use ?
We bottled up in 2l pop bottles the old oil which came out and that filled 2 x 2l bottles and an inch in another, bearing in mind floor and hubby got covered too - so we thinking it drained out a lot to at least 4.5l.
We have put back in 4.5l as this is what we think came out.
Warmed engine, worked gears and did the dipstick.
Confusion sets in here : The engine was on half way temperature as we did leave engine running, hubby drove for 5 mins up the road, came home and we dip sticked which came out about 20mm.
However, we have no idea temperature of the oil - the pan underneath felt hot and the engine was boiling (burn hot) so had to be careful with the dipstick testing.
We don't know how to interpret how much more to put in.
Do we buy a tool to somehow measure the temperature of the transmission oil ? If so, do you know please which tool we need ?
Any other technique that can help us determine how much more we put in ?
fandabby
Hi
This post regards a Chrysler Grand Voyager 2.8 CRD2008
@@SpAwNtoHell
First attempt:
Second attempt:
Third attempt.
Many thanks
