I've noticed this get louder recently so think it's about time to sort it whilst the weather is nice and I have time to tinker!
It's a continual hiss/high sssss noise coming from the accessory belt. It gets louder on higher RPM, so it's related to the revolutions of the belt. I've checked using my mechanics stethoscope and it's not the power steering pump at the bottom, not the a/c pump either. Most noise came from when I listened to the alternator, quite a loud hiss coming from there so I'm thinking this is the culprit.
So, apart from that it's a bit of a guess that it's the problem, do I replace the alternator, or just the alternator clutch/pulley itself as you can buy that separately and replace this on the alternator (My alternator is generally good), anyone done this and does this sound like a decent idea? Or should I just replace the whole alternator?
Also, should I be thinking about the belt tensioner (idler, tensioner and belt) as a replacement too? (Though that's costly)
andyb2000
Hello all,
Any suggestions please folks?
It's 2.8CRD 2005 btw.
Cheers
