Check Engine And Oil Pressure Light Not Working.
acer54
Did the keydance routine and pulled codes P1684 - Battery Disconnected Within Last 50 Starts and P0551 - Power Steering Pressure Sensor Circuit Range/Performance.
How can I clear these codes so that I can recheck at a later date to see if they reappear?
Oil low pressure light now appears to be working after doing the keydance + holding the odometer reset button. (Not sure if this was the reason or not)!
