Driver Side (Lh Steering) Won't Heat Sometimes
VOYAGER1
Hello,
As I mentioned in the "newbie" section, I am the newcomer to this forum.
My car is one of the excellent cars in the area here but; because of the age, I have started with minor problems.
One of them is "the heater'...It actually works fine except for blowing warm, almost cold air on the driver's side (LH steering) while the passenger side is blowing hot air. To eliminate this, I set the temp 24C for the driver and 22C for the passenger and switch to the LOW AUTO. But, most of the times, it does not work and I get almost cold air from driver's side even the LH side temperature is set to 24C when the outside temperature is 2C. It usually happens whenever we go for a long trip. In other words, it happens after a 2-3hour drive during the daytime...
So, what sould be the probable cause for this?
Is there a faulty ultrasonic sensor located in the center dash?
Thoughts will be greatly appreciated, thanks...
