Cold Blowing From Passenger Side But Warm Drivers Side
karlosg
As per the title - We have a 2007 2.8CRD Diesel Chrysler voyager - No matter what setting on the heater, We get Cold blowing from passenger side  but warm drivers side . Its the same in the feet vents and the dashboard vents - I believe it could be a broken flap of some sort that redirects the hot and cold air ? Any ideas pls people ?
Hi.If you get down in passenger foot well and look up you'll see the pollen filter housing. If you can see the bottom of pleated pollen filter the covers missing. Which means it's bypassing heater matrix and blowing cold that side. Like that on mine and heard others same problem.
Solution is to diy cover. I cut a bit of hardboard and duct tape. But someone here came up with half a bit of foam pipe lagging push in fit which been meaning to change.
