Cutting Out, Engine Warning Light Intermittent, Garages Finding No Faults?
Bexb8818
Really hoping someone can help.
Over the last couple of months our Chrysler Voyager 05 has cut out and lost total power. Some times it will start and run fine again, others it won't for hours. More recently the engine warning light has been intermittently on. I've had the car diagnosed by 2 different garages who used several diagnostic machines between them and can't find any errors - no error codes are given at all. I'm a new driver, since October, and drive my 3 children around daily so I'm extremely concerned and losing my confidence with this car. I'd hate to trade/sell as it's absolutely ideal for us but without the issue being resolved it's very worrying.
Has anyone experienced this? Any advice at all would be greatly appreciated.
Thanks in advance.
20 answers to this question
Hi there,
Unfortunately this can be a long list of problems, there are lots of posts on here and on other forums and I did a whole video dedicated to it:
https://youtu.be/ucfZfV1cNng
When you say it won't run for hours what does it do, dashboard light up, you hear the starter motor turning the engine over it just never fires? When it does that if you waggle your foot on the accelerator will it catch and start?
Also, the assumption is the cut out is when you do hard acceleration/over 3.5k rpm? That's the common failure. So back to the list:
  • Fuel filter - when was it last changed
  • Fuel - what fuel do you buy
  • Fuel - put a diesel cleaner/additive through it sometimes helps
  • If the filter has been changed recently, get the filter assembly checked to make sure its sealed properly, has an o-ring. Worth getting it changed again
  • Is it a front or rear fuel filter model? The 05 has different designs, if front check the primer pump and pump it to get it started, if it goes soft it means potentially air/leaking
(Those are just a few that popped into my head as I type, there are lots of posts on the matter!
Engine warning light is a newer one that hasn't been seen in many cases, the fact that the garages plugged in and got no codes means they're not using the right code readers, these need very expensive/special readers
to read the Chrysler codes, so the fact the engine light is on but they see no codes means their reader isn't good enough for the job!
Check grounds/negative wire. Even if think it's good remove clean and refit. Check battery terminals are tight and batteries perfect. How old is battery?Voyager have to have near new batteries or electrics play up throwing all manor of fault codes. Have you had alternator checked?
If all that doesn't solve problems then start fault codes. Find out your ignition key position and turn on off quick three times fault codes will appear in mileage display.
Hi thank you for all the replies.
The garage has done a full service and said going by the condition it looks like it's never had one before. We've only had it a few months. They think the service could have solved the issue but they've now found a problem with the cylinders;
P0202: injector cylinder 2, overcurrent high side
P0204: injector cylinder 4, overcurrent high side
P0201: injector cylinder 1, overcurrent high side
They've told me the service could have solved the issues above as the cylinders were being starved and now they're not so it's a case of driving it and wait and see. If it cuts out again it's a £500 repair so I've everything crossed!! It's driven like a dream since it's service and is starting up without it's juddering noises I was used to so I'm positive - if naively.
Thanks again everyone.
The engine will eventually start but is showing the oil light and as soon as I put it into drive it all dies and loses total power. The garage recovered it this afternoon and will look at it tomorrow. I really hope it is straightforward. Thanks guys
This does sound exactly what I had when mine was at it's worst. At first it just cut out under heavy RPM/load, but when it really failed it did that, cut out basically idling on the driveway.
Also the 'chugging' trying to start was something I've had too, actually mine will still do this when the engine is warm, still haven't gotten to the bottom of that issue but i'm not getting cut outs anymore after working through everything shown.
Go through everything in the video, methodically and work through items that you know are 'known good', as pressure relief valve and filter are easily done at home on the driveway so test the easy things before going to the harder/more expensive replacements.
Unfortunately NO garage will be able to tell you 100% that one thing will fix it, if they do they're lying as none of these issues generate fault codes in the ECU enough to be sure on the corrective action.
Edited by andyb2000
Hi thanks for the reply
The garage found a fault with a cylinder so replaced it, another £300. It's driving ok today although still feels slightly heavy. What's concerning me now is the rpm it goes to 1rpm as soon as I start it up even when I put it into park and am not touching the accelerator. Is this an issue? I am likely panicking over nothing but it doesn't seem right to me.
  On 5/1/2018 at 6:29 PM, bignev said:
Hi Bex,
As Andy's list, the very common one is the fuel filter housing cracking, or a slightly iffy O ring seal.
The Fuel Filter housing was the issue with mine, every since I replaced it, the car has run perfectly. Garages are drawn to injectors for this symptom set, I had mine replaced and it was nothing to do with them, I solved the problem with research online including this forum, not OBD codes. Good luck.
i had same problem with my 2.5crd and 2.8crd
the 2.5 i replaced all filters (not housings)had tank removed and cleaned no luck sold car in the end
my 2.8 had exact same issues
changed all filters fuel filter housing(ie heater/manual fuel pump) still same issue
sent to diesel specialist diagnosed fuel rail pressure release valve
cost few hundred quid to diagnose and get sorted but 2 years in now and im still going strong
my advice is send it to a specialist who knows what they are looking for
my experiences with 2 voyagers the fuel systems seems to be very temperamental
there are post on this forum about these problems already as well as a big write up on the web somewhere that i read
ps when you get it sorted only use premium diesel cheep diesel seems to worsen your problems
this friend made a very accurate diagnosis and I got a 2001 model of 2.5 crd and the car dropped and made some strange movements and sometimes smoke from the exhaust was done by the service controls did not find a solution due to enson battery,
Hi Bex,
Replacing the fuel filter housing worked for me. It was cracked and the o ring inside was distorted. Previously, my mechanic had gone down the injector route with no success. Had 000"s of miles of happy motoring after the replacement earlier this year, not a single reoccurrence of the problem.
