Replaced Leaking Injectors
jawpw
Hello all. First day on the forum….
Just picked up my first ever Grand Voyager 2008 (current model) at the weekend. Really pleased with it.
But as you would expect with a car that age, it comes with a few issues.
It’s just had the injectors replaced. Apparently one was leaking, but the second hand car dealer replaced them all to get it through the MOT.
The problem is, it has a lot of vibration when sitting in idle….especially in reverse.
The dealer said it would require a few hundred miles on it to clear any trapped air from the system.
I’ve done about 300 miles since picking it up, but still has quite a bit of vibration (don’t really know if it’s any different  from 300 miles ago).
Does this sound normal, or does it need looked at again?
