acer54 Posted January 12, 2015 Report Share Posted January 12, 2015 I only have one working fob and would like to buy another, Chrysler main dealer wants a small fortune so my question is if I buy a used one from eBay can it be successfully coded to my car (in other words can it be wiped and re coded)? Quote Link to comment Share on other sites More sharing options...
0 Udtrev Posted January 14, 2015 Report Share Posted January 14, 2015 Hi, no clue if that will work, otherwise could you not try Timpsons, you might get a better deal than from a main dealer. Regards Trev Quote Link to comment Share on other sites More sharing options...
0 acer54 Posted January 20, 2015 Author Report Share Posted January 20, 2015 Hi, no clue if that will work, otherwise could you not try Timpsons, you might get a better deal than from a main dealer. Regards TrevTimpsons can clone and cut a Key from the original - about £40Stealership want £42 for key + £25 for pulling key code and £35 for cutting and coding!No brainer really!!! Quote Link to comment Share on other sites More sharing options...
0 acer54 Posted February 12, 2015 Author Report Share Posted February 12, 2015 Key cut and programmed at Timpson's and the guy is coming to my place to attempt to reprogram the keyfob on Monday - will report back on whether he was successful or not....... Quote Link to comment Share on other sites More sharing options...
0 acer54 Posted February 17, 2015 Author Report Share Posted February 17, 2015 Fob successfully reprogrammed by Timpson's - £30 so well chuffed! Quote Link to comment Share on other sites More sharing options...
acer54
