IanS Posted March 27, 2018 Report Share Posted March 27, 2018 Hi, I had a good lurk on this forum when I bought my 2003 diesel voyager, and I fitted a thermostat in the top hose from info on here. All has been well till the ABS light came on, and I checked under the fusebox for the corroded wire fault, but that was fine.I had a look at the front right sensor and ring, and the ring was very corroded, I cleaned it up with my Dremel, and checked the resistance of the sensor at the plug behind the wheel well plastic, only to find it was open circuit, so hopefully problem found, and a new sensor on order! Quote Link to comment Share on other sites More sharing options...
