bluelandcruiser Posted March 14, 2018 Report Share Posted March 14, 2018 hi have this fault code come onto my 08 2.8crd voyager advised it is possible speed in and speed out sensor, where are they located and is it a difficult job thanx Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted March 15, 2018 Report Share Posted March 15, 2018 Hi, my database show as "Engine RPM input- circuit malfunction.probable cause: wiring CKP/RPM sensor ECM/PCM/TCM. Do you have your RPM showing on the dash?I also found a very useful app on Google Play, "AutoCodes"( with blue and red letters)Where under Chrysler says "Engine speed sensor circuit"Clicking on it it shows possible causes:-faulty crankshaft position sensor circuit ( not necessarily the sensor itself)-crankshaft position sensor harness is open or shorted-crankshaft position sensor circuit poor electrical connection-communication error between Engine control module and transmission control module. Hope it helps. Quote Link to comment Share on other sites More sharing options...
bluelandcruiser
