Abs Light
3ddesign
To test the sensor, it's a hall effect sensor so you can test with a multimeter. Jack the wheel up.
Disconnect sensor, set your meter to AC voltage sensing, low voltage as you'll only get a small amount (20v or lower from memory). Connect the sensor to the meter (easier if you use crocodile clips).
Then spin the wheel and you should see a voltage being generated. If not then the sensor or toothed ring are at fault.
You can also do a basic check on the sensor itself, put the meter in resistance mode and see if it gives you a resistance over both pins, it shouldn't be open circuit, if it is chances are it's broken (Although that would normally also flag up the brake warning light too).
