Badger75 Posted February 26, 2018 Report Share Posted February 26, 2018 Issues after turbo replacement. Quote Link to comment Share on other sites More sharing options...
0 Badger75 Posted February 26, 2018 Author Report Share Posted February 26, 2018 Car was smoking really badly with white smoke. Took to the garage and was advised turbo had gone. So, turbo replaced and intercooler cleaned. Car back, still smoking. Was told that the oil required burning off. So off from Stoke to Warrington, smoking most of the way and way back, worse when at a stand still. On way back, engine just cut out. Now starts and runs for about a minute and cuts out. Back ay garage. Any ideas on possible cause? Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted February 26, 2018 Report Share Posted February 26, 2018 Someone correct me if I'm wrong but white smoke was coolant wasn't it?!?!Check the coolant level and make sure I'm wrong, but it sounds like gasket to me?!?! Quote Link to comment Share on other sites More sharing options...
0 Badger75 Posted February 27, 2018 Author Report Share Posted February 27, 2018 I thought that originally, but not losing coolant. Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted February 27, 2018 Report Share Posted February 27, 2018 Check the info in the link below: https://dogandlemon.com/articles/ownership-issues/diy-diesel-problem-diagnosis Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted February 27, 2018 Report Share Posted February 27, 2018 Oddly these engines aren't "Normal" when it comes to head gasket/block cracks/damage.My previous GV about 5yrs ago had an issue, not loosing coolant, slight creaming in the oil filler but nothing bad and no real impact on performance. Turned out I had a huge crack in the block beside the crankshaft! To be honest the car is probably still able to run now, how I'll never know! So I'm not sure how you'd even know by any of the usual simple signs, but if you're not loosing coolant and still getting smoke it mustn't be using up the water. Quote Link to comment Share on other sites More sharing options...
0 gordy Posted February 27, 2018 Report Share Posted February 27, 2018 Wondering if your Turbo Wastegate actuator is actually working. Hose not connected to boost side after being renewed. Either that or a Turbo hose leak. But low boost might give black smoke unless ECU corrects. Quote Link to comment Share on other sites More sharing options...
0 Badger75 Posted February 27, 2018 Author Report Share Posted February 27, 2018 Thanks for your advice people. Will see what the garage comes up with. He has still got the beast... Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted February 28, 2018 Report Share Posted February 28, 2018 Guys we had it all wrong, look at the link I attached in post #5, it is related to diesel..I know it's weird but according to the article it is. Quote Link to comment Share on other sites More sharing options...
Badger75
8 answers to this question
