2.8 Engine Cover
moxington
Bought a Nov 2008 Grand Voyager but with Engine cover missing
Obtained a 2009 S/H Engine cover - too big does not fit
Obtained a 2006 S/H Engine cover - too big does not fit - both identical
Both are marked '2.8' both only have 3 mounting points - mine has 5
Any ideas where I am going wrong?
19 answers to this question
On the GV rt is not helping with the sound... like making the engine sound quieter... Today i was driving it and i thought is in there only to get home and find that was actually in the garage. over the weekend i will try a db meter test from behind the steering wheel.... i doubt will be 1-2 db quieter... but it looks nicer when bonnet is up and looks like was meant to protect wires etc. I took my one off as the rubbers are aged and i am looking for a solution as i want to avoid the rubbers to perish and rub against something.
I was meaning with the bonnet up, a significant perceived difference. I couldn't vouch for the level from the drivers seat, but it will be interesting, defo.
So then spawntohell, if you'd rather not have it on, and orangecrumble wants one, is there a deal forming??????????
Engine cover/noise cover for 2007-2009 Chrysler Grand Voyager RT 5 mounting (supporting points) 2.8 CRD engine code ENS (VM64C) has the part number 04593809AB
http://i1310.photobucket.com/albums/s658/SpAwNtoHell/20180708_213554_zps14ddrphk.jpg
http://i1310.photobucket.com/albums/s658/SpAwNtoHell/20180708_213646_zpsy7sumkau.jpg
http://i1310.photobucket.com/albums/s658/SpAwNtoHell/20180708_213638_zps2yg0ngij.jpg
And to add to this, i need to clarify, my one is noisy as it seems is missing some rubber grommets that suppose to go in those mounting points on to the engine studs...
Hello again
Here is a link to one of the repair kits on ebay.
https://www.ebay.com/itm/Chrysler-Grand-Voyager-Lancia-2008-2-8CRD-Loose-Engine-Cover-Grommet-repair-SET/323258758220?hash=item4b43b9344c%3Ag%3A~0kAAOSwwAda-~mw&_sacat=0&_nkw=engine+cover+rapair+chrysler&_from=R40&rt=nc&_trksid=m570.l1313
There are several sellers that sell these so i would suggest the you search for the one closest to you.
Hello again
 yes i can confirm they work i already bought them from the same seller, kind of expensive but... i could put the cover on now..
