What Size Wheel
pat19581
Hi and welcome to the forum
Personally I would look into getting hold a wheel to match what your car already has, the space saver spares are a pain in the bum that can only be used for a short time and a slow speed.
May I suggest you have a trawl through fleabay and breakers for a full size wheel - it doesn't have to be a spotless one as it will not be seen most of the time
Hopefully someone who knows the Grand Voyager will come along and confirm that the normal wheel will fit where the spare should be (else you might need to consider where you can stuff it for normal use).
Trev
