Recalls
T14086
Recalls do not apply to all countries, model variants and often only involve a very small production run. If you are unsure if any of these recalls are applicable to your vehicle or you require more information then please ask at your nearest dealership or VOSA.
5582 - Body computer software update
5590 - Ignition coils - Twin air coil malfunction
5601 - Layout - Engine may cut out
5632 - Body computer update - For matrix display
5668 - ABS - Wiring may rub off battery tray causing ABS failure.
5674 - Engine studs - PossiblenNon compliance of engine stud mounts
5678 - Brake servo pipe - Possible brake assistance failure
5686 - Ignition coils - Twin air coil malfunction
5697 - Thermostat - Possible non compliance of engine thermostat
5729 - Body computer - Irregular power uptake when switching car off
5730 - ECU sofware - Petrol to methane switching irregularities
5788 - LPG software - LPG irregular switching and engine light on
5794 - Engine control (1.2) - Irregular switching on of the engine light
5802 - Data plate - New vehicle data plate
