2004 Grand Voyager Central Locking Issue
shami
Hello there. Have a problem with the central Locking. Cannot unlock/lock using the key fob. Have to remove the iod fuse in the fuse box to reset. When this first started happening two years ago, removing the fuse for 1 minute would allow the central locking to work for a few days before experiencing the same problem. Now if I remove the fuse the problem reappears after a using the key fob two or three times. Just fed up. Chrysler says it could be a wiring issue and would need to check all wiring in the doors. I can arm/disarm the alarm from the fob just the central locking is not working. Any advise would be welcome. THANKS.....
