2004 Grand Voyager Central Locking Issue
shami
Hello there. Have a problem with the central Locking. Cannot unlock/lock using the key fob. Have to remove the iod fuse in the fuse box to reset. When this first started happening two years ago, removing the fuse for 1 minute would allow the central locking to work for a few days before experiencing the same problem. Now if I remove the fuse the problem reappears after a using the key fob two or three times. Just fed up. Chrysler says it could be a wiring issue and would need to check all wiring in the doors. I can arm/disarm the alarm from the fob just the central locking is not working. Any advise would be welcome. THANKS.....
Have same problem with my 04 plate voyager have heard it needs a software update and Chrysler are aware of the problem don't know how much they will charge but it should be free in my opinion,I'm living with it at the moment but gonna call Chrysler to check on cost first before I take it in Edited by Hrc43
