2004 2.5Crd Heater Problems
trob86
Sounds like a blend door problem. Could be that the actuator has failed. I haven't had this fault on my Voyager but if it is like a Grand Cherokee, one or both end stops are damaged and the stepper motor cannot calibrate the movement arc of the blend door between fully open and fully closed.
- get some lagging from Screwfix 99p a length - cut to fit in the grill - throw away come summer - do the same next year
- putting a new stat in is a pigs job -  fit an inline stat - 20 minutes - £20 - GATES Part Number TH01489 from rockauto uk
- temp should be just under 1/2, any less than that and you will never get heat regardless
- quick school runs only and you will never get heat from the big engine lump
